Just purchased the Sony KDL-43W807C Smart 3D Full HD TV to replace my old Sony.
I do not really need to use the internet and I have a you view box, there have been updates popping up which are a bit of nuisance as you cannot use the tv whilst they are updating. Could anyone tell me how I can disconnect my hub from this tv? if in the future I decide to use it can it be installed later?
many thanks
Hi there
To turn OFF automatic updates:
