Problems with update V6.7140 for android Tv extremely disappointed after this firmware update for my Tv it’s a disaster Netflix programs in Dolby Vision are hardly watchable images very dark greyed out tried resetting picture and contrast in Tv menu.Dolby Vision won’t allow to change anything.They should do a new update that would include Dolby Vision check box to disable Dolby Vision then we would be able to watch HDR content.Does anyone else have this problem.
Did you perform a factory reset after the update?
If not, I would recommend to do so.
