I posted on here at the start of this year with an issue i was having with blotches appearing on my screen, long story short under the 5 year guarantee Sony eventually replaced my tv in february.
The new replacement is 8 month old and a new issue has arisen with it and im unsure whether or not i should be concerned so any advice would be great.
The screen is 65", and i know sony use a bonding method to hold their tvs together, yup, glue not screws, well as it happens ive recently noticed what was almost like a slight fog around the sides of the screen, about 2 inch wide from the border (Bezel), at first i thought hmmmm, maybe dirty screen so i gently rubbed it with a soft microfiber cloth and it didnt seem to want to come away, whilst cleaning the screen i noticed the entire panel seemed a bit bouncy, odd i thought, so with my figer in the cloth i gently tapped the middle of the screen and indeed it is a bit bouncy, i never previously noticed this so didnt know if it was normal, upon further inspection i discovered what seemed like a slight sticky patch on the top bezel just where it sticks to the back part, upon gently squeezing the bezel ive noticed it is actually quite loose in a few places on the top, aleft and right side of the tv, i gently squeezed the loose parts back, but they dont stay there for long, its like the whole bezel isnt stuck down well and is working loose, possibly with the heat of the screen when its been on a while.
Can anyone relate to this?, surely thats not normal and do i need to be concerned?, its still covered until November 27, but i dont think sony would be happy with sending me a replacement for the replacement lol, should i worry?, i dont want to wake up one morning and my find my tv still on the unit and the screen on the floor lol.
For such an expensive brand, i cant believe how many problems exist with sony tvs, its very disheartening.
