Hello,
We would like to buy a webcam, for conference calls, which is supported by our KD55XG8096 BAEP TV. Can anyone please suggest what kind of web cameras we need to look at? We were unable to find anything, in particular, that is compatible with Sony TV.
Any help would be much appreciated.
Best Regards,
LK
There are no supported cams on Android TV nor any app that make use of it. If you need it for business use you should have bought a pro version of the same. If you look in internet there should be a way to activate he pro-mode also on consumer Android TV and use a camera with it
