- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony KD55XE9305 (HDR)
Hi all just got a KD55XE9305 tv ,one thing i cant seem to get my head around is the HDR, if im watching something using HDR why dont i a see a popup telling me its active like my buddys LG or am i missing something.
ive tried pressing the info button but it shows nothing..for instance i bought a movie from the playstore but i cannot get any info when its playing. or streaming a film from my pc ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Ninja,
Welcome to the community.
There's an online guide for your TV here with manuals that should help you find out more about how the HDR display features.
Cheers,
EdwinaU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ive got the manuals nothing in this of use thanks anyway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you sure the move your watching supports HDR?
Thanks,
Drew
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi yes someone has told me how to check.
click on the action menu during playback and go to picture if the hdr box is on then we are good...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yes, it works.
when i am watching netflix hdr, i press action menu->picture-> on the screen it says App HDR.
although i cant get the same when I am watching kodi or vlc as it stops movie being played.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@bittihuduga wrote:yes, it works.
im watching a film streamed from my pc via nvidia shield ,using SPMC (Kodi) works the same for me .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I downloaded a test hdr sample onto a usb an I also expected a pop up to say that it had detected hdr content and therefopre switched to optimum settings for hdr media. So are you saying that you oly seea notofication of hdr content if yo go into the action menue/picture section ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@romipat wrote:I downloaded a test hdr sample onto a usb an I also expected a pop up to say that it had detected hdr content and therefopre switched to optimum settings for hdr media. So are you saying that you oly seea notofication of hdr content if yo go into the action menue/picture section ?
Yes that is correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for clarifying that.
