Hi my humax box packed up and I purchased the Manhattan SX but i cant seem to setup the IR Blaster like i did with the humax, the Manhattan SX is not recognised if i type it into the search feature. Does anyone know if there is an equivalent/alternative model i can use. Looking back i should have purchased a freesat tv
Hey, @cjd1965 The model seems to be incorrect, can you confirm it using that: Where to find the model name and serial number?
Hi SaturoGojo, your correct it is KD49XG8196, thanks
