Good afternoon ,
Could you pls inform me if this model supports Amazon Alexa ??
I can't find some compatible app in my preinstalled apps...
@geokor11 wrote:Good afternoon ,
Hi @geokor11 According to Sony this model does support Amazon Alexa. If the app has disappeared then I would try a factory reset. It only appears on compatible models.
https://www.sony.co.uk/electronics/support/articles/00186768
If it still doesn’t appear then I would contact Sony UK Support
Good morning ,
Recently updated my TV with the latest software release..
Unfortunately neither after update I didn't see the Amazon App in my apps.
Factory reset is probably a solution but I want to avoid it because I don't want to loose all my installed apps.
Can you suggest me any other solution ??
