Bought this TV last week. Not impressed. Keeps crashing & rebooting by itself. Also, the 4K content is not as clear as it should be. Not getting that true life motion I saw when I bought the Samsung 75Q70 TV. I tried resetting once, but getting fed up with this Android software and sorely tempted to return this and buy a higher model Samsung such as the Q90. Any advice to improve quality of tv and this constant rebooting issue? No software update available.
When it comes to the motion clarity, make sure to enable MotionFlow: https://helpguide.sony.net/tv/haep2/v1/en/01-03-09_01.html
it will also help us help you if you let us know if the TV crashes randomly or while using a specific feature, Also, does it crash when no external devices are connected?
Win_88
Win_88
Thanks for replying. Turned on these settings. Not as real life as on Samsung Q70. Coshes when I was trying to use airplay. glitchy.
