When I switch the TV on there is a brief white flash on the screen before the picture appears. Anybody else got this issue, if it is an issue? The picture is superb.
Hi @bazza525
Is there any way you could video / photograph this for us to see?
I haven't seen any other posts about this from other members yet.
Have you run a diagnostics test in the help menu just to see if that identifies
any problems?
Thanks for reply. Not tried the diagnostics, I will send a video.
cheers
