I recently bought a Sony KD-55S8005C 3D tv & I am looking for a soundbar to go with it
Is the Sony HT CT60BT compatible with it?
Thanks
Hi there
I can only give my opinion, but i would choose the HT-CT80 mainly because of the slight bump in power output. and that the CT80 is a newer model. But i havent heard either one demonstrated on what the sound quality is like.
My advice is to read the reviews on both the Sony site and on Amazon and then make your judgement.
Anybody help please
Hi there
Yes this soundbar will work with the tv you specified - in fact they all will. However, as a bit of advice, i would spend a little more and get a soundbar that connectd to the tv via HDMI-ARC and nor via optical . This will give other features such as bravia sync and HDMI-CEC fuctions such as the ability to use the tv remote to control the volume.
Indeed, its a very good price. However, i guess it is that price as this model is being discontinued - npthing is wrong with the soundbar, just other models have been released. If its what you are after, it is a very good price as ive just been Googling and cant get it for cheaper.
Thanks for your help another question for you
which is the better soundbar the HTCT60BT or HTCT80 ?
thanks
Hi there
