when I single press OK button on an item on the home screen, instead of simply launch it, i get the popup context menu of: Open, Move, Remove.
This happened once before and I restarted the TV and it was solved, this time it is not getting solved restarting.
I think the reason for this is giving Accessibility permission to Tasker.
