- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I am trying to play 4K 2160p video with DTS 7.1 audio from SSD connected to the TV USB using the stock Media Player, audio sent to Marantz amp using eARC.
- No problem with video playback
- Audio starts playing, Marantz show DTS, but after few seconds sound starts to drop out, and then stops, no more sound comes out.
- Tried pause, play, rewind, forward, quit media player and open, change all kind of audio settings, reset audio settings, nothing works, I only get sometimes stereo output when choosing PCM output (other options are Auto1, Auto2)
- Only when I restart the TV, it works for few seconds, then stops again.
- I tried different HDMI cables, some did not pass any audio, others had same problem
- Tried playing using Kodi, getting different problems, it used to have same DTS problem then stops, today it outputs normal dolby sound from DTS track, and I do not understand how this happens, and when pause or skipp, it gets out of sync,
I suspect it could be the HDMI cables, I will purchase an Ultra 8K cable and try, but I am not that optimistic.
Any ideas?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
no eARC on AF9. And even if there is, eARC does not work for internal/streaming apps. Only as passthrough for external devices, blu ray players and such. In a days when everything goes online, pretty useless feature.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@khaeid2 wrote:Actually my TV do have eARC, and I am trying to use it ass passthrough for audio from internal playback
yeah......sorry about that. SONY naming and mess with SoC they used do not help.
Anyway, you can not get any lossless or atmos audio from internal playback (apps). What netflix does is using dolby digital plus for their atmos (which is not real atmos but......) and that is the only way to get atmos from your TV. So for prime or disney or.......... they need to do the same thing as netflix does, it has nothing to do with the rest of your equipment or with SONY. So it won't work for files from your hard drive no matter what you try because it is a system limitation.
But you can get regular lossy DTS or DD from any lossless audio formats with internal player.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you read through all the features for eARC on your TV? Which is the source of your lossless audio ? https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/kd-55af9/article...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After reading the answers and experimenting, I got me an Nvidia Shield and it solved everything, all videos worked simply and output was DTS HD HQ,
I confirm the following
- Sony KD-55AF9 cannot play reliably DTS audio
- Nvidia Shield connected to Marantz amp, produced DTS with no issues on MX Player, and Kodi
- Nvidia Shield connected to Sony TV, again worked properly and the TV passed DTS to the amp, and I got DTS output too from both video players
- Kodi on Nvidia Shieldhad no issues with lip sync, video and audio are in sync so far,
- Advantage to connecting Nvidia to TV immediately is that TV remote controls Nvidia without the need to use Nvidia remote, and the box can be in hidden place too, no need for infrared connection.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you this last one update?:
AF9 has ARC not eARC... But is Ok for DTS...
Edit: Sorry, AF9 also had eARC, like ZF9... 😏
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am trying to download it, but the Firmware I already have on TV is same
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You don't need of eARC for DTS...
The problem is elsewhere...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I read somewhere that normal ARC cannot handle high definition multi-channel pass-through, it can only do 2 channels, only eARC can
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Checking if is PCM in [Settings] — [Display & Sound] — [Audio output] — [Digital audio out] and change it...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
seems not possible to get DTS HD with eARC, i managed in the end to play DTS HD through eARC, but when it gets to some parts of the video full of action with high audio in all channels, the sound starts to cut, and it stops in the higher passages, and then plays ok when the action ends.
It seems I will sadly ditch the Sony internal Android system and get me an Nvidia Shield TV, connect it to my receiver and use the AF9 as only screen, this is really frustrating, I feel I threw away lots of my money in this TV, I could have got only very good OLED screen with one HDMI input for much less money, and connect it to my Marantz receiver, getting signal from Nvidia Android TV
