- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
sony KD 49XF 9005
i have a problem with streaming from you tube because i havent suround sound
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
I'm not entirely sure what you mean. Are you having general issues streaming YouTube on your TV?
Thanks,
Sean Mc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dear Sean,
I try to explain my problem .I have a KD 49 XF 9005 which is in conection with yamaha receiver RXA 1040 which always read the signal from any source of sound .Tv s in conection with modem by wire. When i try to listen any kind material from you tube is always in PCM even though it is set the 5.1 test file from you tube .But in the same time
material from Netflix is ok of course if that file have a 5.1 surround signal
I tried with new firmware from 30. january 2019 , i tried to update you tube apps for android through the google play but nothing
I note that it was my last tv KDL 46 W 905 was able to read it from you tube as dolby digital signal
Where is the problem .firmware ,any kind of codec or tv or anything else
What to do to solve the problem
Thank you very much for your time and help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Materak,
We'll look into this and let you know what we find out. Maybe some of our members can advise you in the meantime.
Best wishes,
Ed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the 55XF9005 and ever since after the Oreo update it stopped sending 5.1 DD or DTS signal to the Yamaha processor. It was perfectly ok before. Connected by optical (toshlink).
I wait for customer support update.
Issue might be of similar nature.
If anything is found, I 'll be sure to post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it is a very confusing because in the same time i have DD from netflix and im so sure the setting from android are perfect but i couldnt do anything , especialy when the KDL W 905 was working fine .
After buying a TV before 2 weeks I try to solve the problem but I do not know what to do
therefore thank you for any help
Best regards
p.s would you like to make connection between 55 and yamaha through the HDMI / ARC connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Tried, byt Yamaha RXV2700 is an older model with no ARC support.
Plays only DD and DTS (i.e. not HD).
Also, tried TV HDMI3/ARC to HDMI IN to processor, nut does not even detect a port.
Anyway, worked fine through optical, without any particular settings in Android 7, before Oreo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
issues number two
remite control doesnt work after
update with last sofware
what going on
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
my remote touch tx100e not working after oreo ?
what ???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi snapisrl,
What's the model number of your TV?
Cheers,
The_Black_Rose
