A recent update seems to have stopped the bbc iPlayer from playing UHD programmes. They worked fine before the update late November. Anyone else had similar issues and found a fix ?
Hi
New firmware released today 6.5016 installed on my 55XG9505 and pleased to report iplayer UHD now works fine
Well, further update to the IPlayer UHD issue. My TV is set to software auto download and I’ve checked that the software is up to date and despite the fact that Sony have responded to a review of the TV that I posted about iPlayer UHD content and said that I should download the latest software (which I have), it still doesn’t play, just titles and black screen. As before UHD plays ok when sound is through TV speakers, but when Sony sound bar is active, no go. So what do I do next Sony?
Are you sure that you have 6.5016 installed, not sure it would have been auto downloaded yet. If not you will need to install it using the USB method
Thanks Rich_B I’ll give that a go tomorrow morning and report back ( too far into the wine now). Re previous advice, yes I’ve tried unplugging for 10 minutes then switched on again and that didn’t work , so I suspect that Rich may have a point and auto download may not have hit the latest software yet
Just press help on remote and look bottom left of screen ,current version is shown there.
Software version is PKG6.0414.0055EUA, so it does look like I need to manually update, thanks again Rich_B
Hi Chas102904
Glad you have it sorted, nice to have the full sound back with UHD.
