A recent update seems to have stopped the bbc iPlayer from playing UHD programmes. They worked fine before the update late November. Anyone else had similar issues and found a fix ?
Yep if I turn off my amp then UHD in iPlayer works as does playback in the other catch-up apps which also wasn’t working! Is this a Sony firmware issue or a Youview issue?
Just unplugged my sonos system and UHD iPlayer now works fine. How very random!
thank for posting this.
Just wonder how Sony/bbc/youview will resolve it?
Hey guys, it seems to me that one of the devices is overriding the other, hence, the power cycle should resolve the issue.
HannahEd01
Following on from these revelations I've found on my KD-XH8505 the iPlayer will play in UHD just by simply flicking the audio from 'Audio System' to 'TV speakers' on the settings menu bar (available via "cog" key ). Flick it back to 'Audio System' and it stops playing.
I'm also pretty sure it plays in UHD when casting from my phone using the TV's Chromecast built-in feature BUT ALSO with the sound set on 'Audio System' with the AV receiver playing the audio in DD+
I am now pretty certain the problem was introduced with firmware update 6.4960 which covers a lot of the xg and xh models
Hi just noticed that Sony have removed firmware 6.4960 from their support pages, hopefully a fix coming soon.
I have installed this software on my KD-48A9. As a matter of interest, when firmware is removed from support pages, do Sony remove the update from the TV or send down a patch to correct the faults?
Usually another update is delivered as a bug fix.
That said, when a version is pulled/frozen or anything like that, there's usually an official statement so I'm thinking this is just a technical or database issue of some sort maybe?
