Hello i have a problem with the above model TV, the android screen comes on the goes to HDMI 1 then turns itself off and keeps going through this cycle. Ive read on the internet this is a common problem with Sony Tvs, the firmware has some how became corrupt ! I have tried doing a forced factory reset but it doesnt seem to be working on my Tv.
I tried unplugging it holding down the power button and volume down then turning it back on and the green LED light doesnt appear it just continues in this loop.
Any help would be appreciated , surely if this problem is caused by a faulty update by sony they should accept responsibility and do they honorable thing repair Tv.
Thanks
Probably a technical issue - please get in touch with an authorized service centre.
Do you have any HDMI devices plugged in ? Maybe try unplugging them if you do and then see .
