x
Sony-Humax sync issues
SOLVED
profile.country.GB.title
ptarmigan33
Explorer
We have just recently bought a Sony TV 49XD8099 which we have connected to our existing Humax Foxsat-HDR via a HDMI cable.
With the TV switched on, then switching on the Humax it Boots Up in the normal way but the TV doesn't automatically recognise it and therefore we have to click on "Home" scan down to "Inputs" scan along and click on "Humax" to connect.
Also if we click on Bravia Sync Device List the HDMI Humax is not listed.
The other input devices DVD and Sound System both sync pefectly.
We have swapped HDMI cables and Inputs and carried out a factory reset the Humax but still no luck. (it worked perfectly with our old Panasonil TV)
I would be grateful for any suggestions as I know this should work
10 REPLIES 10
ptarmigan33
Explorer
Thank you for response, I did eventually
carry out a reset which sorted it and now it’s working perfectly.
Sent from my iPhone
