Hello, recently I've bought the Sony Bravia XR-55A90J the TV is great but I have strange problem and I cant resolve it.
After i change the video(screen) mode to for example (cinema) or change the brightness from max to lower - it changes auto to max brightness and vivid mode in around 10-15 minutes. I cannot find appropriate configuration, please help.
You probably choose store mode instead of the home one while setting it up. Find the option in the setting and reset it.
Hello, thanks for the reply - its called Demo mode and its not on.
There is another option in the image setting to automatically revert it, check that one
Hey Tisho91, check this link out, it tells you how tot urn it off:
