Hi all,
I have Sony Bravia TV Model KD - 55XG8096.
I had external speakers connected via Bluetooth which were working perfectly fine up until a few updates ago.
I tried resetting the TV a couple of times. I tried restarting the Bluetooth. Nothing is working.
Now the TV doesn`t even want to find the Speakers.
Is there any way that this could be fixed or should I return my TV for repair?
My Speakers are LG. I also tried with Sony Speakers - same the Bluetooth is just not working at all.
It`s very frustrating to have a smart TV which is actually more or less useless.
I would appreciate any help.
Thank you
Denis
Afaik your tv do not support any bluetooth audio device...how did you connect the speaker before?
