I was given a Sony Bravia without a remote, watched it just fine with no problems for 2 days, today it turned itself off in stand by mode, and wont turn off or come back on! I did read solutions to turn off ECO mode or timer but i cant even do that since i am not sure where ECO mode is in the settings, i unplugged the t.v. and it did reset and came back on but while looking for ECO mode, it went into stand by mode again.... can someone help this newbie with his "new" Sony t.v.? Please.
Ok, so i got the t.v. to come back on, went to settings, still could not find ECO mode but turn off "go to stand by mode of no source is available" watched 2 minutes of a movie amd back to stand by mode it went! 😡
Does this model have an ECO mode????
Have you tried checking the PC Power Management option as well?
That model appears to be from around 2008/9 so it's quite likely that it's got a fault, it doesn't have smart features and no update is likely to cure this problem I doubt. I have the KDL32W4000 which I got in 2008..... did someone give this to you because they replaced it as it wasn't behaving proplery I wonder?
when your TV turns off, does the led light flash a certain amount of times, sometimes the led flashes 7 times to indicate a type of fault etc. Have you tried plugging it into another power socket in case there's a bad/loose connection there which could cause the TV to turn itself off.
