Hi, I'm wondering if anyone can help with this strange issue I'm having.
I've taken the tv back twice, swapped hdmi cables and used every input on the tv but I'm still having the problem.
What's happening is when I'm on the PS4 and back out to the menu while still in game I'm getting tiny white lines pop up on the lower half of the screen. I've tried all sorts to try and get to the bottom of it.
It's not the PS4 because it doesn't do it on the Samsung tv in the lounge. But it also doesn't do it on the tv with the ps3, sky or Xbox One. It's specifically only happening on PS4 while on game and on the menu. If I quit the game it stops straight away. If I'm just on the menu without a game running it doesn't happen.
Here's a video showing it. https://youtu.be/ZoDxnL44jsk
Hi there
Are you still having a problem with this?
