Worked fine connected to Sky router originally, did set up etc through the same network and router.
Now it says no internet connection, when you go into the network info it says connected.
Also tested networking everything comes up ok and connected.
Have tried everything but factory reset, anyone had this issue ?
Plenty of answer in here if you look for it, just check the date on your tv it should be wrong
