Lost all audio, switched tv off then on again later, audio returned but now poor quality.
Have you tried clearing the cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data) then restarting the TV (hold the power button)?
Yes, it can be done through the remote and it doesn't delete any important data and usually improves performance without needing a Factory Reset, so I'd try that first.
Device Preferences can be found by pressing Home on your remote, then Settings at the top of the screen, then you'll see Device Preferences as an option.
Hope this helps!
- JD
Hi Joe,
Did as you suggested and cleared the cache, it still left 3Mb in storage even though I tried three times (was 8Mb at the start) but the problem remains ,the audio sounds like it's from a cheap transistor radio, have I got to bite the bullet and do a factory reset?
Cheers.
Hi @ecomcon,
Clearing the cached data usually leaves a minimum, so you can look at it as "minimize" instead of "zeroing out", and I think you should go for a factory reset yes. 🙁
- JD
Hi Joe,
Decided to "Bite the Bullet" and perform a factory reset, and it seems to have done the trick.
I was concerned that I may have lost track of Netflix history, but needn't have worried!
Thanks for your help
