Amazon prime app taking so long to load, then crashes with error message stating insufficient bandwidth, which is utter nonsense. Netflix shows download speed of 45gbs and performs seemlessly in all respects.
Would appreciate any input regarding this annoying gltch as previously it worked OK.
Prime app takes forever to load then crashes with error text stating insufficient bandwidth. That is total nonsense my Netflix app shows 45gbs and runs seemlessly with no issues whatsoever.
I would appreciate any help with the problem.
Thanks in advance.
Thomas.
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
