HI,
I've recently purchased the abopve TV which has bluetooth but I have found that it does not support the use of bluetooth headphones.
Is there any way I can use bluetooth headphones by using a bluetoooth transmitter plugged into the headphone socket on the TV.
If I can does anyone have any recommendations for the bluetooth transmitter.
Thanks
Hi @Gemandy,
A very warm welcome to the Sony Community! To best answer your question, it all depends on the type of Bluetooth headsets you already have or are planning to purchase. For watching TV I’d personally recommend to purchase headphones that support aptX Low Latency mode. This way you ensure you will not suffer from out of sync issues between sound and image. So that means that you also will have to purchase a Bluetooth transmitter which supports the aptX-LL mode. You can find links to possible transmitters and more detailed information about your question on this post.
Hope that answers your question.
Cheers,
Dutchice
Thanks for the reply.
I've got a cheap set of bluetoth headphones that I tried on the TV but the TV would not locate them. I then discovered my TV does not work with headphones.
I'm going to buy better quality headphones and will ensure they are APTX LL with similar transmitter.
Thanks again
Doug
