Put photos into folders on a USB drive. Select Album and then folders. The photos are sorted newest first. I want to use slideshow starting at oldest. How do I sort differently? Other answers mention using "options" button on remote. I don't appear to have one. Also the screen has what appear to be a menu at the top left hand corner but I can't find how to access it.
Hi there
I tried to do the same a little while ago, unfortunately i could figure it out either. I suggest that you install an app called Kodi as it has far more functions
