Is there a way I can control my VU+ Duo2 and Mac Mini through my Sony KD-55S8005C Android TV please?
Hi there
Unless the devices support HDMI-CEC, then the answer is no. If they do, simply enable the option in the devices settings.
However, have a look at the Harmony range of all in one remote controls and see if your devices are compatible.
http://www.logitech.com/en-gb/harmony-remotes
