- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
August 2019
August 2019
Sony Android TV IR Remote Strange Problem
In the first video, the control does not react, although I press repeatedly. Nothing happen.
In second video, the remote control is very close to TV about 5 cm distance.
When tv remote very close to tv then remote work.
IR Remote dont have any problem .im sure about that because i have 2 remote they both same. i tried Factory reset , installed new firmware and Hard Reset nothing helped. . i only can open tv behind buttons.
Sony W805C . .im on last update 5435
2 ANTWORTEN 2
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
August 2019
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
August 2019
August 2019
yes i did everything there but nothing helped
