So I move into my new home and my wife decides that I can no longer hook up my existing Sony AG9 TV to rear surround speakers via my AV receiver because of "too many wires". Given that you can use the screen of the AG9 as a soundbar is there a possibility to have a couple of wireless rear surround speakers to get 5.1 sound without having obtrusive wires all over the place?!
Hey @Shoodie, you can connect speakers to the TV wirelessly using Bluetooth as explained here bearing in mind that you won't be able to output audio from the TV speakers and the external speakers connected by Bluetooth at the same time as explained here. If you want, you can get the Sony HT-A9, The four speakers connect wirelessly to the control box so there’s no cables across your living space. I hope this helps
