I recently purchased a KD65 AG8BU and for some odd reason the television keeps coming on by itself after its been switched off . This has happened more so when I've switched it off using Google Assistant but now its also happening when I use the remote to switch on and off the tele. Need some help please
Hi there,
Can you check if the [On timer] is activated. You can disable the [Auto TV on] setting in [BRAVIA Sync settings].
Best wishes,
Sean
