Whilst watching standard tv, the tv shows full screen,then some adverts are then shown in wide screen format, the next advert full screen and so on.
The problem is worse watching you tube, with the tv changing from wide to full during the same film, it appears every time the film changes its view the screen changes.
My previous sony handled the same ads and you tube and never changed its screen size. Am I missing something quite obvious here, I have changed a few things in home/settings screen ratios, but nothing seems to work
my tv is a KD 55AG8. thanks for any help guys.
Hi Donyderek,
Could you try to enable auto wide mode?
Cheers,
The_Black_Rose
Hi Donyderek,
Let me know how it went.
Cheers,
The_Black_Rose
I believe that almost all movies are made with either horizontal or vertical borders (bars) depending on the director's vision, it's not something specific to your TV, I have the same thing when using my phone, laptop and TV as well, even in the cinema. It's just a fact of the way the content is shot, processed and then presented to you, the same is true for the ads and Youtube videos.
Display / Screen
Wide mode FULL
Auto wide. OFF
4:3 default. OFF
Auto display area. OFF
Display area. FULL PIXEL."
Change auto display area to on/Auto
