I have just got the Sony A90K 48" TV. I am very happy with it. I decided to get the Sony HYT-S40R sound bar to go with it.
I have the sound bar plugged into the HDMI 3 earc port on the TV. I also have a Sky Q 2tb box plugged into HDMI 1. If I have the sky box turned on and watching TV, then decide to turn on the sound bar, it turns on and a toast message appears say it has connected. The problem is when it connects the screen goes black for a second or 2 with the toast message.
It is a little annoying. It doesnt happen if I use bluetooth, the toast message appears over top of the screen. Is there any recommend settings to stop the black screen happening while the soundbar connects.
Hi @Elodin
Is there a way that I can setup the soundbar via optical? I tried Bluetooth but my Samsung Q950A does not auto connect to the TV. I have to go into the bluetooth menu and connect each time. My Sony mk4 and mk5 headphones auto connect each time I turn them on.
Optical cable could be the way to go if I can get it to auto connect when it turns on
Yea you can also test it with an optical cable, I think it even comes with it in most cases.
