Hi, I bought Sony 9305 and I tried to connect it to Wifi. In the Password-field it says you should press Select-button. I can't find it. There is no Select-button in my Remote-control. Is there any solution to that?
Cool - Glad you have managed to get it working
Maybe finnish was too complex to this tv. When I turned it to english select-button worked and now wifi works fine 😎
Same issue with my sony telly. My language is already set to english. On screen keyboard doesnt appear when you hit the middle button on the remote. Thought it might be to do with keyboard so changed that from gboard to multi language keyboard in settings. Also turned on a virtual remote keyboard but still same issue. Cant believe this is even an issue! Surely everyone who connects on wifi has to get round this by downloading a phone app or plugging in a keyboard.
This solves nothing. It is just instructions to how its supposed to work!
