Hi, my remote has stopped work except the voice control still works! Have tried another brand new remote and same issue!
Does anyone know how to fix? TV is up to date and I have rebooted and reset it several times. Frustrating!
Hi Ogre1235,
Please check our trouble shooting video:
https://community.sony.co.uk/t5/how-tos-faqs-tvs-home-cinema/troubleshoot-your-sony-tv-remote-contro...
Hopefully it helps to solve your issue.
Try to manauly install the latest software on the tv (worked at a friend when only one button had problems)! Also,try the remote with another Sony tv!
Hi @Ogre1235
There's a way to test the remote control's IR signal: https://www.sony.co.uk/electronics/support/articles/00025283
Win_88
