Hey all, just found this page thought id make a post to see if anyone can help.
Im new to Sony Android tv, just bought the 65X89k, and im having a few issues with sound, preset sound settings, where you can select a preset choice like, sport, music, cinema etc, Most tvs have these options but i cant find it anywhere at all on mine. I have done a google search but found very little info except reference to customising your sound with these options.
Mine doesnt seem to have them, the only way i seem to be able to alter my sound is by a built in graphic eaqualiser, i add that i dont have a Set top box, this is set up with the satellite cable connected directly to the tv for freesat as i also only have a sky dish, no aerial.
I did wonder if the options im looking for are only available through a Hdmi cable connection.
Any help appreciated, im baffled by the lack of these settings.
Hi, sound mode is actually a feature that is either available or not available on specific models. Checking the specifications of your Sony KD-65X89K, I can see that Sound mode is not available as a feature on your TV. Specifications. I hope this helps.
