I bought the AF9 because it was lauded for having an excellent acoustic sound system from on screen activators which i presumed meant you didn't need additional sound bars.
This was important because i live in a semi detached bungalow with a neighbour who suffers from multiple sclerosis and is affected badly by noise so i am trying to be considerate.
Unfortunately, while watching most films it is impossible to hear the dialogue clearly unless the volume is turned up to a ridiculously high level resulting in the music being excruciatingly loud.
Does anyone know how to rectify this situation?
Hi
Try to update the TV software as it might be the reason, the latest version should be 6.5042.
Hope it helps.
