Since the lastest firmware I keep getting a pop up on screen with 3D movies in the bottom left hand side.
"Screen Format: Full" this is of course say it is using full pixel but it should not keep showing!
I cannot seem to find a way to disable this notification. It makes 3D useless as it keeps popping up! I even tried a factory reset to no avail.
Yes, definitely agree. I've done all those things above and told Sony I've done that. Even copied in their worldwide and UK heads. I still get their stock responses.... But please if you have a Twitter or Facebook account post complaints as so far it looks like I'm the only one to have done that? They won't take action if one person complains publically but if more do.......
P.s. if you do tweet a complaint to @sonyuk don't forget to send it to @bbcwatchdog as well.
Just posted to their Twitter UK page and will link to Watchdog as well.
Hi all - ok, I finally got a substantive reply from Sony UK to my many emails. Not good news though - the February update has been confirmed, and the 3D issue isn't even listed as a fix to be made. I'll respond asking them them about this. They have offered to extend my warranty by six months. Oh what joy!
The fault will be fixed at the next round of fw updates, scheduled for end of feb. Cheers
While the extended warranty offer is nice of them, I'm still demanding an explanation of why the UK is the Ugly Stepsister while the EU and US have already gone to the ball as Cinderella in December. Why does it take Sony UK two more months to provide our fix?
Hi all
I think I have discovered what causes screen format full. If you change your motion flow settings from Standard to Off,it should stop it.
I am in talks with Sony but it seems like much of the same - getting nowhere and forgotten about - having said that though when I had a Samsung, they wouldn't even accept there was a fault with the TV! It seems like all the big TV companies have gone down a bit
Thanks for that, it appears to work but concerned we can't use motion flow though.
I returned mine to currys yesterday. They were very good about it. Accepted that I had a genuine excuse no questions. Picked up a Panasonic which behaves as it was marketed to and also has hdd recording available now, not sometime hopefully in October/December/March. In my emails with Sony I had no confidence that they were going to sort the 3D issue out. Discussions with the guy at currys suggests that a lot of purchasers don't use the 3D once they've bought due to the scary cost of genuine glasses (despite the fact 3 different generic ones had worked perfectly on my Sony).
I'm sure I'll have some form of issue with the Panasonic (oh I did, Panasonic tuners aren't Unicable compatible). But I got sick of being fobbed off by Sony support. Took 3 emails for them to finally admit that they had known about the issue.
@Patrandec wrote:While the extended warranty offer is nice of them, I'm still demanding an explanation of why the UK is the Ugly Stepsister while the EU and US have already gone to the ball as Cinderella in December. Why does it take Sony UK two more months to provide our fix?
Ireland received another update:
Improves sound quality issues: v3.169
Firmware 28-12-2015
http://www.sony.ie/support/en/product/KD-55X8505C#SoftwareAndDownloads
