Hi there,
From some time last year, after an update, whenever I use the remote to switch on my Sony Bravia KD55XF759, there are several long start up screens with the Android and SONY designs. Whole bootup takes over 1 minute every time.
This never happened before the update. Is there a way I can remove these to speed up boot time?
Thanks in advance.
Maybe you can try a Factory Reset... But with Factory Reset you lose your Settings ad installare Apps.
