How do I get Skype on Android TV and which camera should I use
Hi there
Skype is not supported on the Android TV platform. However Microsoft have stopped supporting Skype across all Smart TVs from all brands.
See:
https://community.sony.co.uk/t5/the-lounge-room/skype-no-longer-supported-on-tvs/m-p/2184174
The best bet is to buy an external Android TV box with a camera that can connect to Sony TV, as Skype is not supported on TV-s any more. For instance you can check out [URL removed by moderator] that could be a solution for you.
