The Sky remote has always been able to control the volume on the tv's I have had in the past, including a Sony LED for 10 years. The new OLED A1 will not respond to the volume control, even though the Sky control will power off the tv.
Have been in contact with Sky who suggested some different codes, but still does not work.
Can anyone help, or does it need a Sony fix?
Had hoped with the recent software upgrade it would be fixed but has not been
Roly
Hi there,
Do you have the latest firmware installed?
Best wishes,
M
