I’ve just noticed a single faint vertical dotted line about 3 inches in on the right of the screen. Any ideas on fixing it? Thanks
Not so much to try to help you... not a tv model nor a photo... In general terms, panel problems are not addressable without a technicians (and mostly it is too expensive anyway)
It is surely a component that failed. You should check it out with a Sony support center (it could be the panel or the board managing it)
