I have purchased an Android TV - Sony 49XE8005 (49XE9005 has never released in my country) at last summer and after a couple of weeks it setup by onsite service, I started using it.
Some features of my TV is not functioning correctly.
Then I start thinking that the processor on my TV is less than minimum requirements.
But I couldn't get local support for it yet.
Do you have any suggestions to fix my issues?
Hi Nohackmove,
I would suggest you break down the issues and post them individually so we can help you resolve them more effectively.
As an example your first issue will require quite more information to follow up. And so goes the same for most of the rest. Which will make things cumbersome to handle all in one post here. I also already can tell you that by searching keywords about your individual issues you will find the solution and if not, hints to most of your issues here.
Cheers,
Dutchice
