***** se selecteaza de pe telecomanda programele in ordinea dorita?Mentionez ca nu pot intra in programe selectate
Can you please post in English on this UK community? Bing Translate is a big help, if you need it.
e.g. Your first word, likely harmless in Romanian, seems to be an obscenity in English....
You might also want to look for a Romanian Sony Community, if there is one, as some issues can relate to region/country differences in models and features,
Iti trebuie sony channel editor. cauta-l pe google. Il iei pe PC si cu un stick USB faci toata treaba.
For EN readers: he's looking for a way to edit the TV channel order. Pointed towards the sony channel editor.
