Having trouble seeing a FaceTime call, on my recently purchased KD43XH8096 TV, using AirPlay, from my Iphone
Image comes up on the TV in portrait mode and cannot be turned to landscape mode, resulting in a smaller image, than expected
Really need a system, whereby the iPhone automatically switches the TV to pick up the FaceTime call, without having to alter any settings, on receipt of the FaceTime call.
You cannot do it better also on an apple tv, why do you expect on a Sony TV? https://www.howtogeek.com/344324/how-to-facetime-on-your-apple-tv/
regarding portrait or landscape vision, I cannot state it for sure on iPhone, but on android you just have to turn your smartphone to switch the view also on the TV
My tv doesn't have native airplay protocol so I cannot test it by myself but using android mirroring if I put my smartphone in landscape it stays the same on the tv. Just playing remotely the facetime time app on the tv maybe different but in any case it depends on apple software why do you blame sony? Maybe you should check on apple support if there is any restriction or workaround
