ScreenRecording - finally works on Oreo!
profile.country.GB.title
khallergard
Member
Screen recording has been a disappointment, till now.  Tried 5 apps:  DU Recorder and AZ Screen Recorder work, though without their overlay menus.
 Vlog: https://youtu.be/7283xx7FoUg  Blog: https://tinyurl.com/y4km97xr
Mobizen, Recordable and ScreenRecorder 5+ (by NLL) do not work.
Have not found anywhere to allow permission to "Draw over other apps"
Demo trying 5 apps on Sony Bravia Android TV - Oreo. DU Recorder and AZ Screen Recorder works, though without the overlay menu. Issue: nowhere to permit "Draw over other apps". Written companion: https://tinyurl.com/y4km97xr Screen recording with audio: https://youtu.be/YxwEOuGUta4 ...
Tags (1)
2 REPLIES 2
Pascale_F
Moderator
Hi khallergard,
Thanks for this. Did you need help with anything?
Thanks,
Pascale
khallergard
Member
Thank you Pascale,
Howto enable permission to "Draw over other apps"?   (this was the main issue I encountered, affecting most of the apps in one way or another).
Thanks,
khallergard
