I'm struggling to set up stream mirroring on my xe8005 Bravia with my Samsung can anyone help please.
Hi Rockpoolie
Is there any particular stage do you get stuck at?
Are you using the Quick Connect button on the S7? (used to be called screen mirroring).
I've managed to sort this now its called smart view
