Is there an app for android tv
that is like FreeSat
and gives you a proper epg etc and access to the catch-up services etc.
YouView/FreeView is crap where I live
but I have a satellite tuner.
Sony don't do FreeSat for some unbeknown reason!!!!
is there an alternative to utilise the satellite tuner
many thanks in advance
Hi there
There was upto a couple of months ago. Sony made a rather decent app called "Video and TV Sideview", however due to unknown reasons, they have basically discontinued it and turned it into a remote control app. It was great for Freeview and I think for Satellite too.
Sony dont do Freesat - correct. If Freesat is important to you, I would suggest looking at available devices/boxes that can do it.
