profile.country.GB.title
1Terry229
New
Satellite problem
How to I tern the satellite off to view normal tv
4 REPLIES 4
profile.country.DE.title
Peter_S.
Genius
Don't perform a satellite scan during initial set-up.
1Terry229
New
To late for that.I need to know how to turn it off.
Thanks
Joe_Dohn
Specialist
You can factory reset the TV.
Tuning the satellite channels without a cable might remove them, but not sure to be perfectly honest.
Hope this helps!
- JD
1Terry229
New
It's a
OK now my son figerd what to do.
thank you all
