I've recently just bought a SONY BRAVIA KD65XH8096BU 65" Smart 4K Ultra HD HDR LED TV with Google Assistant and it won't let me run my xbox at 4k at 120Hz. I've got enhanced mode on each hdmi port and tried the xbox in each hdmi port too.
Is there anything else I can do?
I'm pretty sure the TV is capable of running at the spec says 200Hz
Thanks!
If I see the specs of TV correctly, panel dot 50 Hz so i dont know where you got 200 Hz info. As well the hdmi specs says 2.0, and as i recall, for 4K playing 2.1 is requirement, 2.0 hdmi doesnt have enough throughput, sorry.
cheers!
The 200Hz is when MotionFlow is enabled. This is great for watching videos/movies but not good for gaming. If you want a TV with HDMI 2.1 features, look at the Sony XH90/92 series.
It's my pleasure
