Easy Question, not that I can find an answer, but does anyone know where a description of the button functions on a RMT-TX100D remorte control is.
Hi there
Which model TV have you got? The description of the remote control buttons is usually in the reference guide for your TV.
thanks, I looked through the user manuals and couldnt find this. Where does it live, the link downloads the PDF so i cant spot it.
Thanks again
Hi there
Search and select your TV model from this link:
http://www.sony.co.uk/support/en/series/prd-tvhc-tv-lcd
And then select the link "view all available manuals"
